Rear hatch/spoiler delete
stanced-trash96'
Sep 23, 2013
Salem, Virginia
New guy to the dsm world. I own a 96 talon tsi, wondering what the best route was on deleting my spoiler or swapping out the oem one. Interchangeable parts from the eclipse? DIY? Best place to order this from? Thanks guys !
Also will the 2g eclipse trunk hatch fit with no fabrication on my talon?
The Talon and Eclipse hatches are the EXACT same(Never minding the wing/wing holes)
I believe the stock Talon wing has 5 bolts holding it on, after you take off all the plastics. I taped over some(With sealant on the inside), and just threw the Eclipse high rise on.
thanks man thats the simple answer i was looking for haha, i appreciate it!:thumb:
use bondo to cover old holes
Don't listen to this unless you want to do it the wrong way. You should always weld holes shut, grind down the welds, then use filler to finish it off. Then prime, seal, and paint. Also, ALWAYS seal the exposed metal on the bottom side of the hatch with a self etch primer then undercoating or paint.
