rear end..
indhp94
46
Oct 17, 2008
prescott, Wisconsin
most likely will get flamed for this. awd rear end is it possible to use 2g rx7 rear end? or just fab up some solid mounts for the stock rear? sorry if this is just out of control.
the thing i would do is check what the gear ratio is on that rear end
next check dimentions of the rear end
then then would probly have custom fab your rear axels to accept the rear end
also the were the drive shaft bolts will have fabed and customized to accept the shaft
or it u dont plan on taking too many turns, weld the center diff and call it a day
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
