rear end
myturbo
445
12
Nov 28, 2008
wichita, Kansas
:confused:I was wondering how i tell if my 92 eclipse has a 3 or 4 bolt rear I do know it is a limitedslip rear diff dont know it that means its a 3 or 4 bolt thanks to any one that can help !!!!!!!
92 is the best year to have because they are all(actualy not 100% if there was a split but most are) 6 bolt 4 bolt as in 6 bolt crank and 4 bolt rear. As for LSD or not all you have to do is lift the car up off the ground on a lift or jack stands and spin one side and the other tire should go the same way.
3-bolt rear axle assemblies have 3 bolts attaching the axle to the wheel hub. 4-bolt axles have 4 bolts, as well as beefier axle cups, and are therefore far stronger.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
