Rear diff or transfer case hit while boosting
AlphaVision
297
Jan 28, 2007
Sofia, Europe
When I am driving the car normally it drives well.
When i hit the pedal and the car is in high boost I get a loud hit coming from the rear. Like a hammer smashes my crossmember or I hit a huge rock under my car. Or at least I think is in the back. My guess is the rear diff or maybe the transfer case. What could possibly do this? Is it a bad transfer, broken gear(s) in the rear diff.
I am not sure but if I were you I would first jack up the car and go through all the bolts and make sure they are all tight.I am FWD but I had a sound like you described but from the front.I jacked it up and went over all the crossmember bolts.One was really loose and I cranked it tight and have not heard 1 clunk since.
I will check those. Thank you.
Just to add that I just did an AWD swap and started driving the new AWD car on Sunday. I got my parts fron a non-runnig car and don't know on the conditions of the rear diff and transfer case. Transmission is rebuilt.
Actually I got brand new UMS Tuning v2 bushing set (3 pieces) for the rear diff. I had to reinstall those because they have direction and the first time I mounted the diff the polyurethane was coming out of the aluminum housing. So after I turned them they were positioned so the front was stopping the rear from coming out and vice versa.
This weekend I will check them if they are loose.
Thank you, guys.
