2G Rear Camber spacers?
whiteice2x
Aug 3, 2003
mundelein, Illinois
I have a 1995 GSX, just confused wear to put washers and how many?? I got a 3" drop, yes its fing low....and i have put some in put my rear ensd seems to sway all crazy, im sooo confused...pics nepone...some assistance would be great, thanxs alot
The washers go behind the brackets that bolt the rear upper control arms to the frame. Take the wheel off and look at the knuckle. The a-arm at the top has two brackets that attach it to the frame. Unbolt the 2 bolts per bracket, grab some longer bolts, slip a couple washers behind the brackets tighten them back down and viola!
http://roadraceengineering.com/eclsuspension.htm
scroll down to the camber correction kits. i actually bought the $40 rear kit because theres not a single store in town that carries bolts of the required hardness. it supposedly corrects the camber for an eibach pro-kit drop, so you could add a few washers and still hold onto a degree of neg. camber
  • Wanted GSC S2 Camshafts
    GSC S2 Camshafts
    • jmt2028
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
