rear brakes grinding??
not sure if this will help but i had a "ssshhhhh" noise coming from my rear brakes and i washed and sprayed a ton of soap water from a garden hose all over them and tried to get it all up in the "pad to rotor" surface and it magically went away! i would def check to see if the pads or rotor are wearing funny or grooves ground into the pads/rotors
This happened on my sister's prelude. The rear was going through a set of pads in less than a year. I had to change the calipers. Works like a charm now.
Not sure on 2g but our 1g calipers are actuated so be sure to pick up an actuated caliper square tool if you are going to be checking for a frozen caliper. If when you say they "were just changed" you mean you had a shop change them just take it back to that shop and tell them the problem, they should be more willing to remedy it for you.
