1G Rear brake swap
obsidian
393
5
Jun 25, 2007
New Orleans, Louisiana
the 1ga rear brakes are horrible. We're always upgrading the fronts but I've not seen an upgraded rear that is swapped from another vehicle.
Anyone know of a decent swap to get some bigger rear brakes to match the bigger fronts?
Read that and only found some info that I wasn't looking for. I see info there, but not what I'm looking for.
No one seems to upgrade these things.
So part of my asking is, is there any KNOWN direct swaps?
I can lock up all four with sticky wide tires (after the dual piston front upgrade) so unless your road racing and need to handle more heat, why do you need more rear brake?
I might be able to use slightly different proportioning to add a little more bias to the rear but I didn't swap to the 93+ AWD valve when I did the calipers. So it's a little easier to lock the fronts first.
