2G Rear ball joint?
galantracer53
172
Sep 21, 2012
schaumburg, Illinois
So I was looking at my gsx earlier and saw the rear has ball joints on them and my question is why?? I thought ball joints only were for wheels that turned that car so I can't seem to figure why they are on the back? Does anyone know the reason for this??
[ame=http://en.wikipedia.org/wiki/Ball_joint]Ball joint - Wikipedia, the free encyclopedia[/ame]
The parts articulate, don't they? The diagram is for a 1g but it should illustrate the point.
Got it. I just thought if was alittle weird ### I've never seen it before I thought it might've had something to do with the awd system but I wasent sure so figured I'd ask
Oh and in the title I meant rear ball joint not read
The arms that have the ball joints are also directly related to controlling the amount of toe in/out on the rear. Normally yes, bushings would suffice as the other two lower arms as well as how the upper arm mount are done and I suspect that's how all other cars with unadjustable toes in the back are done.
As the arm pulls in/out to adjust for toe, the balljoint rotates whereas if it was a bushing, the bushing in the arm or on the knuckle itself would deflect to accommodate the increased angle. Couple in with the fact that as the suspension cycles up and down which also affects toe and it soon becomes obvious a bushing would not work in that position.
Got it. Except for the ball joint on the one control arm?? And hypothetically speaking could I make my gsx have rear steering????
There's a ball joint off to the side of it. Like there's 2 control arms. There's the one that goes right the the knuckle then there's one that looks like it would be a tie rod
Would that be more beneficial then the ball joint???? And where would I get one? And how would I put it on??
I don't follow the question.
Never mind in think we were talking about 2 different things. I thought you were saying that I could replace the ball joint with bushing
