rear alignment?
idt512
231
9
May 4, 2003
Hemet, California
after lowering my car, does the rear toe setting get affected like the front does? Im not sure if I need a 2 wheel or 4 wheel alignment for a 2g GST.
yes your car will need a 4 wheel alignment. Most cars with an independent rear suspension will require an alignment after you lower it. Cars with a solid rear axle "usually" dont need one because the camber/caster/toe does not change with differences in ride height unless you hit something
