REALLY WEIRD, what's in my AC???
justincredible
Banned Member
502
Jun 20, 2002
ChicagoLand Area, Illinois
Ok, finally got around to doing this...
Changed AC Resistor...still makes loud hum noise...
Took out blower motor, it was fine, but I found a ton of leaves/debris in it as well as...took those out tried it again and i finally got some air through the vents! Although, still made very loud humming noise :notgood:
Took all this stuff out again and while I was poking through the vents through the blower motor I found more leaves, and I do mean MORE...
So I think I've come to the conclusion that the humming noise is because all of the leaves in there? There is still more leaves in there and I can't reach them through the tiny vents with my hands. First question is, how/can you remove this bottom part in the pic below? I circled the places where I took out the clips and screws. I know there are a lot of leaves in that area.
The second question is, how did all that junk get in there? I'm starting to think there is a rodent or bird or whatever inside there, but how could they've gotten in? I need help LOL
thats the turth but a very comon problem. mice get in the blower motor more often that a guy realizes
How did the crap get in there, the HVAC system takes in outside air for cooling/heating purposes. It can take in some debris but usually not that much that was defenatly some kind of furry critter looking for a home. As for the box to open it up you have to remove it from the car and then open it up.
