re-installing my head
95tsi-awd
Dec 13, 2004
Deltona, Florida
this one sholud be easy lost my book and need some tourqe specs and tighting pattern oh and i allready now i cant spell so no need to bring that up :thumb:
Use the spell check then :toobad:
Are you using stock head bolts or ARP head studs?
Hrmm...
Well, I've heard bad things can happen if you twist either way more than one full turn....
...but you might have worse problems if it became unattached.
^^ haha funny stuff right there. With ARP lube its 81 ft lbs. With 30 wt motor oil it is 105 ft lbs.
7 3 1 5 9
10 6 2 4 8​
That's off the top of my head. If I'm wrong, someone please correct me, and to the original poster, I'd wait for a conformation before using my sequence, as I could be wrong.
Also, torque down the nuts in steps, not all at once.
Edited to try and get the numbers to line up.
