RC 1600's injectors
CPHunter
1,005
Aug 3, 2004
Winnetka, California
I just want to know if ima have a problem here, I know are stock injector is 3ohms and these are 5ohms. Does that mean i can't run these things? some help would be nice. i got the lower injector seal to fit right.seals like a normal injector, just machined the lip off and removed the seal and ran the stock injector seal in its place, and the top seal fit like a glove. Just this ohms thing is getting me to scratch my head :pray:
Peak & Hold Injector PB2-1600
The 5 ohm resistance on those RC injectors will more than likely require you to run a injector driver box, you might encounter idle and partial throttle problems without one.
:dsm:
okay cool, its not about the money at this point, i just don't want to turn the key and burn the damn ecu up
ECU's like ours are designed to drive low impedance with the use of a resistor box, which means they can also drive high impedance injectors without damaging the ECU. Good luck getting the car to idle with those puppies, I'm not sure what your using to tune but the new dsmlink V3 firmware enables you to run individual injector deadtime for big injectors. :thumb:
:dsm:
Since you've got v3 you might not need a injector box then to run those RC injectors, just download the new firmware if you haven't already. Let me know if you need a link or a "how-to" on tuning those RC 1600's...
:dsm:
