perrytheplatypus157
- 85
- 66
- Jun 18, 2017
Fall River,
Wisconsin
What could be causing a random misfire? It seems that the only time the car starts to knock is once it misfires. We've replaced the plugs(Br7es gapped at .026), wires(stock 7mm), ignition coil, TB, different injectors(450s, 560s, and 1000s) battery(XS deep cycle) and voltage doesn't seem to make a difference nor does throttle position or AFR. In the log I've posted, there may be some times that the belt is slipping so voltage drops, but the issue has been around longer than the belt slip. The alternator tested good twice by two different auto stores. Any guesses? Thanks
Specs:
1g manual
14b turbo
91 octane
Exhaust
EVO MAF
Injectors
FMIC
Aeromotive 320 pump rewired
Fuel lab AFPR
Specs:
1g manual
14b turbo
91 octane
Exhaust
EVO MAF
Injectors
FMIC
Fuel lab AFPR
