Radio and wipers not working
Birt96gst
117
4
Aug 28, 2005
black diamond, Washington
I just installed some SPW gauges in a a-pillar pod and when I went to check them I relized that my radio did not come on. So I went to check to see if any hing else didn't work, and the front and rear wipers don't work nethier does the cigarette lighter.
Help me please I cant figure it out
I tapped into the acc wire off of the ignition switch the one that is atached to were the key goes in
Well if the fuses are good you either tapped into somewhere you shouldn't have, cut a wire by mistake or you may have a bad connection (ie if you used those "fang" or crimp connectors instead of soldering them)
