Radiator measurments
RedGST98
262
Jun 22, 2011
Alamogordo, New Mexico
Has anyone bought this radiator and using it now?
Mishimoto Mitsubishi Eclipse Aluminum Radiator 95-99 | eBay
reason I ask is that I am going to be buying one but I need one with the neck off to the side to clear my manifold..
If you have one like this, could you tell me the distance it is from the side to the middle of the upper inlet? and also what the core width really is?? need to make sure i have enough clearence.. my turbo blanket rubbed a hole in my old one :(
First, the Mishimoto radiators are super popular around here if you need any reviews on them
You have a tubular manifold right? Most people buy the 1G radiator to fit into their 2G. The 2G radiator has a centered inlet on the radiator vs the 1G inlet which is more towards the passenger side.
The 1G radiator, on bottom, has two dowel pins that need to be cut and rewelded in another position to fit the 2G bottom mounts properly. You would use a 2G/1G lower hose, a 1G upper hose and cut it a bit shorter
http://www.dsmtuners.com/forums/newbie-forum/213275-1g-radiator-2g-merged-5-08-a.html
Not sure on the thickness part, I don't use an aftermarket radiator yet :)
LOL I know they are pretty popular... tahts why I asked if anyone could shoot me the info on the size..LOL
I have read that whole link and nothing telling me about the size as yes I have a tubular t4 manifold that is making me have to use the inlet on the side. I heard there was some modification taht needed to be done.. tahts not gonna be a prob... just want to make sure I will have the clearence of the manifold.. and also how thick it is to make sure i have the clearence from the turbo to the fins as the last radiator I bought i had to move the neck and the turbo blanket just rubbed a hole in it yesterday...
unless someone wants to trade manifolds.... :) its a T4 with 50mm wg flange.... jk
