Radiator light flashes once boost hits
2gGSX
1,956
31
Feb 15, 2004
St. Louis, Missouri
Some threads I've searched have said this is due to a blown headgasket, even though compression test results come back fine (155 163 160 160 for me).
Has anyone else experienced this? I started it up after a turbo/FMIC install with what I thought was enough coolant, then about 5 minutes of driving I noticed the radiator pagoda light hit after entering boost, then my engine temp needle steadily rising. I tried limping as much as I could then got to the side of the road immediately and shut it down. Based on the last coolant temp reading from DSMLink I believe the maximum temperature it reached was around 240* maybe twice, could this be enough to damage the headgasket? Does anyone have any other ideas to at least re-assure me?
Edit: I'm a moron and should be more persistent with searches; the light indicates a low coolant level so I probably just haven't filled it all back up yet (somehow).
240* is not a normal temperature for your car, but if it just peaked at that and came back down I wouldn't be too worried.
As you found out, the coolant light indicates low coolant, but only in the reservoir. I used to get that light on high g turns or when executing a donut-like manuver. The coolant in the reservoir gets splashed/slammed against the side of the bottle and leaves the sensor momentarily oncovered.
Check and add coolant in both the reservoir and through your radiator cap. Once it is full, drive around for awhile and see if you are loosing coolant. If you are, please post back and we'll further diagnose your problem.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
