quick question on first start on new lifters
FIBA M - EC17PSE
Supporting Vendor
6,808
5,321
Nov 1, 2008
Orlando, Florida
i already know i need to prime them but thats if i had just the revised 3g lifters! BUT i have the gsc with the stiff spring that keeps pressure and pumped up even if no oil is in there. so i dont know whether to pull the mpi fuse and do some bursts or just start it up and let it do its thing that way.
i just need to know if im safe and just starting the car?
You should be fine, With my 3g lifters after I took them out and cleaned them I just dropped them back into my head, started my car and let the car warm up. But I also did an oil change as well so that probably helped in getting the lifters pumped up.
oh everything is being changed. even the belts, i just dont want it going funny on me upon start up,
also i doubt changing the oil helps on pumping them up!
Does anyone else have any experiance with the gsc lifters and if i will be ok on just starting the engine with oit removing the mpi fuses
can any one else chime in as to if i will be ok doing this?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
