quick n/t to turbo maft wiring question
zaebst
143
Feb 19, 2003
Grand Rapids, Michigan
i'm just finishing up doing the swap on my 90 galant gsx and there is one main thing that i'm hung up on. i ordered my new maft and everything for the setup to run.
now the stock n/t maf has only 6 pins where as the turbo maf has 7. the two things i'm mixed up on is are the two maf plugs for the n/t and turbo 1gs different from eachother because the plug for my maft is a little wider and clearly will not plug in. i've got the wiring figured out for the 7th pin i just don't know how to connect the two systems correctly. do i have to go snag a turbo 1g maf pigtail in order for it to be 'plug and play'?
the other thing is that same plug only have 5 of the wires going directly to the plug. then there is an extra long white wire which i understand where to connect that but the instructions for maft don't mention where the second purple wire connects.
can anybody try and help clear this up so i can get this beast running?
What i did was cut the right side of the plug off (if you are looking at it on the MAF side)so it would fit into the MAF receptical, then ran a wire from the ecu for the 7th wire of the turbo maf and put a small spade terminal on. It worked great. Hope i explained it well.
i think i get it. so the turbo maf plug is bigger (wider). and you cut part of your stock n/t plug off so it would connect in. right?
