Questions.. IM lost..
MiSFiTz
56
Jan 5, 2004
Chillicothe, Ohio
Ok, help me out here..
I got a 97 Eclipse GSX 2.3L bottom end coming... stock head (well besides what i wanna add below)
I need to know if the mitsubishi multilayer hg will hold up to high boost on a fp green w/ a 2.3L bottom end? Im also looking for arp head studs cheap, ive checked ebay and stuff but they got like 3 different part #'s LOL Help there too?
Also i would like to get a set of cams.. but the money is tight, so wheres a cheap place to buyem? and should i go w/ 272 or 264's?
Thanks in advance..
Yes the Mitsu MLS will hold if it installed properly.
Buy the ARPs, ebay, this site, and dsmtrader are the only places I would expect to find them cheaper than new. Make sure that you have the correct ones for you block ( 6bolt/7bolt dependant)
Cams are preference, however I would jump straight to the 272s or FP3s... or if you want something a bit cheaper, get the BC 272s.
2.3l, I would go strait to BC280's. Lots of people have been deep into the 10's with stock OEM head gasket/ARP combo's. Metal head gaskets need a finer RA finish done on the deck surface and head to seal correcrtly, and stay together better at higer boost. Cost's a little more. There are pro's and cons to each. A stock head gasket will be the weak sause in the engine and will fail (hopefully) before you cause any significant damage and seal to just about any simi stait surface.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
