questions for ya plugging engine
alltheway2drag
76
Jan 8, 2012
Trois-rivieres, QC, Canada
Hi i have a couple of questions starting with .. where does the injectors plug to ? ( i mean the bar of injectors)
and what is the fire order and distributor ? ( eagle talon ESI 93 )
and exactly where does all the osses from the intake plug to ?
and do i need the plug that goes to the headers (3-4 wire , white gray and i dont remember others)? because i broked mine.
Ahhhhh.... I do not recall ever seing a distibtor on a 4g63 engine... you should have a coil pack
common guys :p .. coin or what ever you call it .. the 4 spyplugs has wire(or osses) what ever you call it .. whats the order ? .. and where the plug to in order i call it a distributor... whats the order there too .. thank-you
order of spyplug to coil pack .. thankx
and where does the intake osses plug 2 .. thankx
can i know why no one helps me ?
i want the fire order (spyplugs to the coil order)
and exactly where does the osses on the intake plug to ?
I bet someone does know all that thank-you !
and for how much can i get a o2 front sensor (on header) ?
