99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
OK, I just read VFAQ's "Reading Compressor Maps" article and I have a few questions.
LINK = http://www.vfaq.com/mods/Turbo-compressor-maps.html
In the acticle, it makes a reference to atmospheric pressure being 14.7 psi. Is that a standard number or does it vary? I mean, is it 14.7 everywhere or did they just use that figure as an example?
I also had a couple questions about the surge limit. It says "You also do not want to operate your turbo to the left of the surge line, the surge line the left most line. This only happens when you have a big PR at low airflow (big boost at low engine RPM). Surge is a condition similiar to stall over an airplane wing, the flow becomes turbulent over the compressor vanes and the compressor surges in and out of boost and all sorts of weird things happen. You'll definetly know if you're operating in the surge area."
What kinds of weird things happen? What would you look for or listen for? And also, give me some examples of when you would have a high Pressure Ratio and low airflow.
Thanks in advance. -Paul-
