Question on my starter i pulled out of my 420a
Talon96esi
49
Feb 20, 2013
Blue Ash, Ohio
Hello again everyone, finally got time to pul the starter and needless to say, its chewed up..when i got the last bolt holding it in loose, i heard something drop through under the car, I picked it up and it was a head that broken off a bolt, it also was chewed up. im wondering if the grinding noise that i was getting when i turned my key was the bolt head lodged in between the starter and the plate that covers most of my flywheel... what do you all think? My car is a 95' Talon ESI automatic transmission. Thanks
Where exactly are the bolts located for the torque converter? Im new to this type of issue, never touched a thing when it comes to auto trans. This is the first auto I have owned, so im a lil lost LOL
Do you have the head of the bolt? Torque converter bolts are short and have a "+" imprinted on the head. There should be 4 bolts total. Pull the inspection plate off of the bottom of the tranny and turn the crank to reveal each of the converter bolts. The grinding noise could have been a combination of a bad starter, the broken bolt or worn teeth on the torque converter itself. You do not have a flywheel.
Technically he has a flex plate.
+1 on removing the inspection plate and check to make sure all 4 converter bolts are there.
