Ludachris
Founder & Zookeeper
- 8,855
- 4,703
- Nov 12, 2001
Newcastle,
California
I've seen Jake Lathem's write-up on his FRH manifold install. I noticed he went through the trouble of tapping the manifold and using studs to mount the power transistor to the manifold. My question: is there a reason why one should not use the bolts that hold the plemum to the runners? I was thinking of just making a few brackets and bolting them to the manifold using the same bolts (well, probably longer versions of those bolts). It would basically be the same as using washers. Any reason why this would be a bad idea?
Here are the bolts I'm talking about:
