question bout a clutch
Mar 1, 2006
Catlettsburg, Kentucky
i searched for it already, and couldnt really find the anwser...sort of did but not really....so ima ask anyways...............
95 talon tsi fwd
i did an auto to 5 speed swap...all i have to do is hook wiring back up.
my question
i changed the "auto" wiring harness and put the 5 speed wiring harness in...so everything should hook up.......but i noticed that the wiring harness thast in the car is a lil different (plug on clutch pedal)...the wires that makes u push the clutch to the floor to start......
the auto car doesnt have the 5 speed wiring harness thats under the dash so that plug isnt there...so will the car start or do i need to do some wiring some where?
If you have all the regular plugs for accessories, etc, you will be fine. Mine is disconnected, because as i've heard, it puts constant pressure on the Throw Out Bearing, everytime you are going to start the car. Leave it disconnected, it won't harm anything.
