Question about valves and guides.
yes they will fit, but if your thinking of knocking them out of one head and installing them in another head, I would rethink that.
Brand new guides are about $3.00 each , and depending on how the guide bore is, you may need +.001 or +.002 od guides to keep the press fit proper.
also the INT and Exh guides differ.
also after the guides are changed the seats will have to be cut .
this should explain alot about changing guides.....
http://www.dsmtuners.com/forums/newbie-forum/341218-how-change-valve-guides-4g63t-head.html
changing guides out is NOT something that should be done in your back yard, unless you have the tools and equipment to do it properly.
