question about slicks
you only need tubes if you are running them with really low air pressure. You should be able to get by without them.
well what do you guy consider low pressure. i was planning on running like 10-15 psi. and whats the smallest size wheel you can fit on a 2g with stock brakes?
start at 20psi with fwd.. work your way down 2psi at a time.
When i was fwd with my honda, 7.5psi was the sweet spot, I ran tubes.
when i had my honda i ran 10-9 psi but i guess the weight of the car is a big factor when it comes to what psi to run
