Question about mounting clutch master cylinder
mini zilo
783
18
Jul 17, 2006
Chicago, Illinois
Alright, I am in the process of doing an automatic to manual swap in my 96 gsx. I just got my master cylinder today, and I already drilled the holes out in the firewall for it. I have a question about how it actually mounts to the firewall. On the "flange" part of the master, (the part that bolts the firewall) There is a stud, and on the other side, and empty hole that is slightly bigger. Do I just use a nut and bolt to secure it?
You slide the master cylinder over the stud on the firewall then you have to screw a bolt through the inside of the car out through the threaded hole in the master cylinder. I can get the correct size of the bolt for you later when I get home if you would like.
  • Wanted 6 bolt NT water pipe
    • chrisman287
