Question about Freeze plug
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
I had a leak through the freeze plug,which is under the intake manifold. I bought a rubber one,that comes with the nut in a middle.So i put that one in and after couple days it started to leak again.... My question is: If ill put the metal (OEM) in there,will it stop the leak?? Is there any possibilities,that the hole,where the freeze plug goes can wear out???
I would replace that with a metal freeze plug, those expanding rubber plugs are more of a temporary plug.
I use anaerobic sealant when I do them.
LOCTITE® 510
510 Gasket Eliminator is a single component, medium strength, anaerobic sealant with good heat resistance. The product cures at ambient temperature when confined in the absence of air between close fitting metal surfaces
It does not have to be Loctite brand should be able get it at any auto parts store.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
