Question about exaust leaks
dsmoverboosted
217
Feb 26, 2006
Winnipeg,
Can exaust leaks in an exaust manifold cause an engine to shake? Also would the o2 sensor read lean and add more fuel?
No, but a shaking engine can cause exhaust leaks. The O2 sensor reads the proportion/ratio of oxygen in the exhaust stream, not the "actual" amount. So no, an exhaust leak will not affect the O2 readings. Not unless it's a big enough leak that no exhaust is left to pass over the sensor ;)
Actually if there is a leak prior to the o2 sensor it can cause it to read lean. Why do you think guys with a cracked manifold have bad o2 readings? A leaking exhaust system will allow outside air into the system which contains o2. That extra o2 can effect the readings if it is a big enough leak in the right place.
accually i messed that up. my trims are at 80% so the o2 says rich and is removing fuel. So would that be possible?
