question about camber kit (NOT DO I NEED ONE)
IIv SHaDoW vII
369
May 8, 2007
Topeka, Kansas
It is adjustable. You rotate the eccentric bushings in the front; you add/delete shims in the rear. Those are fine.
- Jtoby
Thanks, and btw I pmed you bro, haha. Ok well if these are fine then I wont need you to answer my pm. I appreciate your help.
For the Tokiko HP system (mentioned in the PM, for those of you keeping score at home), you only need to shim out the rear upper control arms about a quarter inch. The front can be left alone, unless all you care about is drag racing. The extra front camber is better than stock for handling.
And don't forget the alignment, since shimming the rear adds toe-out, which eats tires.
- Jtoby
