StarCraftLover
- 188
- 0
- Oct 2, 2002
stafford,
Hi,
I have a question dealing with boost creep. If you have a boost leak, can you still creep to really high levels of boost? Like 20+ lbs?
After I installed my profecB boost controller, I can't really seem to get an accurate boost control. I'll set it to max boost, and it will hit 13 lbs and fall back to 11. Then I'll readjust it lower and the boost will fly to 20 lbs or more...
Most of the time though, I'll try to set it to 15lbs, and the boost will goto ~15 and then fall to 11 or so lbs. Why? Is my boost controller installed incorrectlY? Or is there a boost leak that I might not know of? I was under the impression with a leak, I wouldn't be able to get such high level's of boostcreep.
Thanks in advance,
Martin
Thanks in advance,
Martin
