boost creep
eclipsegsx97979
78
Nov 2, 2004
springfield, Massachusetts
took the car for a drive today after changing the exhaust manifold and i noticed that when i was in first and 2nd and punched it the boost would spike to like 25 psi... seems to be boost creep how do i get rid of this? i have a t3/t4 50 trim turbo internal wastegate, boost contoller, intake fmic, i/c piping, fuel upgrades and all that....
kevin
Does it spike or does it creep? 2 totally different things. Spike is reaching a boost level, then slowly falling, while creep is reaching a boost level, then slowing creeps higher.
at this point its spiking at like 25 psi.... i did notice a while back it would hit a certain boost level then go up a little bit as i went faster....
Who makes your turbo?
What o2 housing do you have?
Here's how I controlled mine.
I have a 50 trim also that's internally gated.
I hogged the o2 housing out a ton.
I payed even more attention to the wastegate tube on the housing. I ported it a ton and then polished it to a smooth shine. Stock, it's to small to flow enough exhaust through, to control your creep.
I then port matched the housing and gasket to the turbo and port matched the housing to the DP
After all was said and done, I could run 15lbs rock steady. It see's 21 daily now with no issues
Good luck
i did notice it creeping on me today when i was on the highway getting higher in speed... the position im in since all the stuff ive done to my car is that im flat out broke now LOL. is there anyway to fix this boost creep problem with having to get a manifold and wastegate?
Yeah. Search and reading is your friend. But since you prolly won't, I'll give you the answer. Port the wastegate hole.
what turbine hosuing u have on that 50 trim? my pte boost creeped so i got a bullsye performance housing and pulls harder and no creep at all thanks to there bigger 38 mm internal setup
...... im flat out broke now LOL. is there anyway to fix this boost creep problem with having to get a manifold and wastegate?
Like NOSLO2PT0 said"reading is your friend"
I guess you missed post #4 I just told you how to eliminate it...LOL
good luck
