ILLegit420aT
- 88
- 1
- Jan 16, 2008
Cowtown,
Pennsylvania
how much is a quaife lsd...are there any cheaper comparable models...and also i got my 3.55 final drive neon gearing!!!!!!!!
I heard the carking lsd works pretty well.. You may have to get in touch with them... They are a site vendor!
Wow, I'm not one to call someone out, but you really need to search. Try searching before you start a new thread. From what you wrote in your thread I would definitly have to say that you havent even looked. Were here to help, not spoon fed you every answer you are looking for.
VelocitàPaola;151383064 said:Also, KarKing doesn't make LSD's for the NV-T350, only for their 4G63 counterparts.
I've heard nothing bad (but nothing necessarily good) about the AMC LSD. OBX, as always, requires modifications to strengthen its inherent flaws.
My apologies....
VelocitàPaola;151383078 said:In all fairness, the MSRP of a Quaife is almost common knowledge: $1250, give or take a few dollars depending on the vendor. Here is one thread I saw a little while back that sells them for much less. I've never heard of anyone buying from this company before, though.
Team 2GNT Forum - Viewing topic #6718 - Quaiffe lsd for cheap!!!!
www.manufacturersdepot.com Browse By Manufacturer:Quaife:Quaife ATB Differentials:Mitsubishi Quaife ATB Limited Slip Differential LSD Category
VelocitàPaola;151385783 said:Um... okay?
That sentence doesn't make sense, and this is the link you were trying to post:
Quaife Differential Application List - Autotech (949) 240-4000
i payed 1200 for my Quaife
j/k Where did you get quaife at?Most places charge 1200+ for the Quaife.
Well I don't see why you would dime up when the manufacturer only charges 1095
VelocitàPaola;151387354 said:Try buying one directly from the manufacturer. The price discrepancy is a result of retailer's markup, etc..
i've been looking into the kaaz lsd, and there doesnt seem to be anthing wrong with it. It looks pretty solid and from what i can find on power ratings it should be good for 600wheel. I dont know if theres any problems drivability wise though
