Q: 1992 Eclipse Tachometer Lead/Wire????
TegJay
Jun 9, 2004
San Angelo, Texas
Does anybody know what color and where to locate this wire somewhere in or under the dash? I am installing a shift light and I just need to find the tach lead to splice into for the light. Someone help me out if you know where I can locate this wire or a place that could point me in the right direction?
I tried just about every wire underneath the dash that was said to work and none did for me, untill another memeber said to use the White wire under the hood that is by the coil.
It is bunched with 3 other wires.
Good Luck~ ;)
well I know there is a lead for my turbo timer under there. But I am not sure the pulse on it. If you like I could find the install directions
