1G Putting eclipse door on talon, plastic moldings?
lasershark
1,607
236
May 17, 2013
over yander, Idaho
I have some eclipse parts to put on my talon, both doors and both fenders. My question, what is the best adhesive to use to put the plastic moldings from the talon on to the eclipse parts? The cars are 1gb.
And any helpful tricks or advice in removing and installing the plastic moldings would be nice. Junk yards in my city suck, 2 doors and one fender are from my gsx that got totaled recently and I was lucky enough to find the only clean fender I needed off a junk yard car.
Thanks
I would suggest either one fabricating a flush body moulding clip and then drill a hole on the body parts that line up with the clip and it will lock on. Or another option would to use the 3M 10LB Velcro. I used the velcro on a moulding on my Lexus for a quick fix and it does the trick!
Using small sheet metal screws on the bottom of the door and some good 'ol fashion 3m double sided tape should do the trick.
