DSM Jeff
- 558
- 7
- Jun 23, 2003
Connecticut
Ok I'm debating on putting balance shafts back in an engine for my fathers car. I'm in the process of building my father his 2nd DSM and my old/new engine will be going into it. I had removed the balance shafts and am considering putting them back in or putting brand new ones back in to reduce vibration in the car. I'm also staying with rubber mounts.
I'm just wondering if anyone can see any ill affects of putting balance shafts back in an engine. I would obviously install new bearings. But I'm trying to understand what causes the shafts to break or seize? Should I go with new shafts from the dealership? The rotating assembly was balanced when it was built.
You may think I'm crazy but this is going to be more of a stock car, small 16g, small fmic, fuel mods, 2.5" exhaust. Just something fun for my old man with comfort in mind. My car has no balance shafts, poly engine mounts as well as poly subframe bushings and vibrations travel through the whole car. He's not going to care for that.
Thanks.
Thanks.
