2G purge control valve
DSM_JAY
61
Apr 9, 2009
Tampa, Florida
ok I did the Taboo speed vacuum line removal, and what a difference. now my only question is the purge control valve and canister check valve are sitting there not doing much can i just remove that whole assembly, and if i can what should i do about the line coming up from underneath the bulkhead.
you can remove it, since you are a 2g you might get a CEL im not for sure, but as for the line that's under the canister it is a ventilation hose just put a valve cover breather type filter on it, if you pinch it closed the vapors will have nowhere to escape and cause really bad problems.
