GVR-4 purge control solenoid valve
15psi88
163
3
Aug 10, 2004
Lewistown, Pennsylvania
Since i took off the charcoal canister and all the emissions stuff do i need to keep the purge control solenoid valve in. I know its not a big deal, but if its just going to be there doing nothing i might as well remove it. thanks alot.
and yes i searched
Defiant said:
I believe removing it from its circuit will prompt a CEL. -Anyone?
I was thinking that as well..... but wasnt sure if OBD1 would pick it up..... Then again it is emissions related....
Try it and see. Worst that can happen is the CEL comes on.
What would cause this thing to make a knocking noise. It is loud enough to be heard in the cockpit.
Just like 92awddsm I took out all selenoids & emissions. No CEL and no "loud enough to be heard in the cockpit" All you need is 3 vac lines, Boost Control, BOV, and FPR :thumb:
