Pumping my clutch pedal
dammitblnk182
Oct 31, 2005
Plano, Texas
I just installed a new master cylinder and everything works fine exept the clutch pedal. I mean it has enough pressure because it shifts gears, and yes i have bleed so all the air bubbles are out. But everyfew hours i get in have to pump the pedal a few times do that it has enough pressure to shift. I think it might be something wrong with the slave cylinder. Also When i shift into reverse the clutch grinds, but only when i shift into reverse. Any suggestions are welcome. Thanks
Sounds like the Slave Cylinder to me, I had the same thing happen and Napa sent me the Master Cylinder by misstake. I then replaced that, problem did not go away..Re-ordered a New Slave Cylinder replaced it and that fixed the problem. Make sure you bleed your lines really well. Hope this helps
