bmxfelon420
- 652
- 62
- Sep 6, 2005
Napoleon,
Ohio
Hey all, been running my car for almost a year pretty trouble free, then last Saturday I pull away from a stoplight and hear a whining noise. I noticed that it slips a bit when this happens. If I give the car very little throttle it seems to not slip and accelerate ok. When cruising at speed there is no notable noise. The transmission still shifts into all gears and lockup just fine. The noise is not present when in park or Neutral. The only thing I noted that was at all out of place was my fluid level when hot was a bit high. I drained about 3/4 quart out of it and it's back in the right range.
Second problem that popped up when this happened: Park is now acting more like a brake than stopping the car at all when stationary. If I put the car in park, it can creep very very slowly. Not enough to notice at first, but I went inside for an hour, came back out and the car rolled back two feet.
I'm at a loss and wanted to see what anyone's opinions were on what this could be. My current plan is to drop the pan, inspect everything, replace the filter with a new one, and new fluid. If it still has issues after this I was going to pull/inspect the pump and swap it with a pump from my parts transmisison. My theory as to the sudden slipping is that the filter is either clogged, defective in some way (I replaced it last year), or the gasket between the filter and the transmission is leaking and the transmission sucks air on occasion instead of fluid. Here's a video of the noise and behavior, any ideas or suggestions are welcome.
