Pully removal
ninjadave
59
Jan 26, 2012
Port Charlotte, Florida
First off I've seen other pully DIY forums but haven't found exactly what I'm looking for, so sorry in advance if this is a repost. Okay, so I'm having an issue with removing not the crank pully, but the sprocket behind it. So I'm gonna say the balance shaft sprocket? How can I go about removing that? The reason is because there has been a balance shaft elim. Kit installed but the bearing were not installed so I have to remove the front case but having trouble getting the "sprocket" off that rest behind the crankshaft pully. Any suggest would be appreciated. I've tried heating and using a puller and no luck just braking more stuff.
Yes, the center bolt is removed. They could just be very snug on the key then cause I've tried a lot to pull them off and no budge.
