drive pully removal
Nate_Hustle
Jul 26, 2011
Madison, Wisconsin
what is this gear?- it goes into my timing belt and seems to want to come out when i remove the main drive pully- is this supposed to occur? its seems to be attached somewhere. i have pulled the main bolt and the four front bolts holding the pully onto the front of the motor. the pully just wont pull off without pulling this gear out. am i doing something wrong? am i missing something?
That is your crankshaft sprocket. You only want to pull the 4 small bolts off the pulley and not the big center bolt. Put the big bolt back in and tighten it up. Then your pulley will come off without the crankshaft sprocket.
What are you taking this stuff off for? Replacing the timing belt or what? Here is some good info Timing Belt VFAQ
am i pulling the pully off? the remover i have seems to be pulling it off unevenly and b4 I wreck stuff... is this right? it seems to be pulling it off on the right side of the picture frst. im probly just a nervous nelly but i dont want to wreck my baby!
only the outer ring is coming off- how does the center of the pully come off if the outer ring comes off with the puller?
you have to take the center bolt off to take the pully off. i broke the pulling doing what you said. theres a spring pin that was holding it on after i took the center bolt out. with the bolt out it took me 30 sec to get off. thanks for the advice.
