James92
- 11
- Jun 16, 2025
Yakima,
Washington
I pulled my ECU and have a questionable SMD cap under my 100uf 16v cap. I was going to replace my capacitors and also came across some stuff under my eeprom so I’ll need to investigate that but the SMD has me scratching my head. Insight from the community is much appreciated.
Reason I pulled was due to some irrational shut off and back on scenario, like a ground touched then came back to life. Went away for a little while but came mysteriously and figured I’d investigate the ECU. I get the CEL when I’m on position with key and can hear 1/2 clicks from the MPI (haven’t tested)
Edit: I did notice the burned pad, just don’t know why the SMD would bridge over the opposing trace.
