pull trans bearing race
er82
247
35
Apr 18, 2014
Sacramento, California
I'm in the process of rebuilding a 1G 5spd awd transmission. The case has many bearing races that should be replaced. Is there any puller tool set that works the best for pulling out the bearing races? I have HF 2 jaw puller set, but the jaws are too thick.
I use a small slide hammer with a custom end. Only a few of the races are press fit. Many may seem like they are but in reality its just really close tolerance. The worst one to get is the input shaft. I use a stack of washers like a pyramid and ground to an edge so I can get a lip under the race. Mitsu probably makes a tool but ive never looked into it. Just made what I needed. Ive done dozens like this.
I used a combination of otc 4796 bearing race remover and filed down HF hook to be used with hammer. Some races came out with little force, but none were hard.
