ptw clearance and proper end gap. HELP!!
FP3065TSI
173
Mar 27, 2008
Yakima valley, Washington
Okay I was searching around for a proper ptw clearance and a good end gap for the 2G piston. I am using the 1g rods/2g piston combo that dsmgraveyard sells. Should I be using the 2g piston end gap and ptw clearance? :confused:
i would think that u would use the ptw clearance for the 2g piston.....considering its a hyperneumatic piston and not just cast....im not for sure exactly how much the 2g piston epands....but the bore on the 6 and 7 bolt are the same....85mm....so if you use the ptw on the 2g piston it would be no different thean installing it in 7 bolt block
