PTE 6765 Vband inlet and outlet
wvturbo2
1,164
Jan 25, 2006
Huntington, West Virginia
I just received my pte 6765 and I am wondering if anyone else is running one of these with the vband inlet and outlet. I'm a little concerned about the tiny inlet on the turbine side. It will be a little while before i have the car back together so i was trying to see what experience people have or what they think. Thanks :hellyeah:
Sent from my ADR6400L using Tapatalk
I am not using a 6765. I am using pte76. I am using a vband on the inlet and the outlet. My inlet is bigger than yours, but that is due to the larger size turbo. I think that you will be fine.
Well if its good enough for you all its good enough for me . A 2inch inlet just seemed small
I wouldn't call the inlet tiny. It's properly sized and the housing works rather well. So much so that most of our t3 manifolds are being replaced with v-band manifolds shortly.
I agree with what you are saying. I was making reference to the size of the two housings. This is why I sad I think that he will be okay.
Where do you get a 2inch vband with the lip big enough to fit the pte turbo
