PTE 50 trim efficiency range?
turbo95dsm
37
Sep 2, 2003
What psi does the PTE 50 trim start to come alive at? I know the turbo was rated at 30psi but what is its actual efficiency range?
It'll be fine as low as 10-15 psi.
Keep in mind that compressor efficiency is not as important as compressor sizing in general; you need to make sure that the wheel can support the amount of airflow you need, but efficiency changes of a couple percent, to even ten percent, really do not have a large effect on power.
http://users.wpi.edu/~ktarry/dsmtech/compefficiency.html
turbo95dsm said:
I should notice a pretty considerable change in power from 15 to 20psi, right?
Yes. 25-40 horsepower would not be uncommon, with proper tuning.
I see 22psi at around 3800rpm with 10-16 counts of knock on 93 octane. That is with a rough tune after a rebuild. I'm trying for zero knock, but I have 9:1 Wiseco's.
