2G Prothane Rear Lower Control Arm Bushing
Zmann42087
840
21
May 9, 2005
Portland, Oregon
I have a question for those of you who have installed the Prothane "total" urethane suspension kit on their 2g. It pertains to the one bushing in the kit that is NOT the simple split design that makes installation so easy. This is bushing C-10042 shown in diagram below that is used for the rear lower control arm and the rear toe arm. The instructions I have pictured suggest that you remove the urethane portion from the steel sleeve prior to pressing into the control arm. Is this correct? The urethane ends are not easily removed at all.
That is correct, due to the step in the steel sleeve. And the whole point of the bushing is to be stiff and tight. You will most likely need a press.
Taking the center bolt bushings out and then removing the poly pieces should alleviate some of the hassle.
I got it taken care of but I did have to use a shop press. No way were they coming apart or going into the LCA by hand.
