Prothane motor mount question
Dude3000zx
120
Mar 11, 2010
Athens, Alabama
WIll the inserts for the left engine mounts press into the right tranny mount also?
Im asking because Ive found the left engine mount insert but cant find just the right tranny mount insert for sale anywhere, just wondering if it fits both sides.
thanks!
I just received my prothanes you can get them individually but i do not understand why you would the set is cheaper
thanks!
It has been a while since I installed my Prothane Motor Mounts, but I thought that the passenger and driver side mounts were the same diameter. Could be wrong though.
Also, they do not need to be pressed in. After the OE rubber and ring are removed, they slide in by hand, and the metal bushing fits just fine.
I just looked at my spare passenger & transmission mounts. they are the same.
Prothane lists all 4 mounts for the 2g as different part numbers. They also list that all 2g cars use the same kit. So if indeed those 2 mounts are the same then maybe their listing for the application is wrong, or that non-turbo means the 2.4 liter and not the 420a.
On a 2g turbo the passenger trans mount and driver engine mount are 2 different sizes. I have a set sitting in a box that are about to be installed and they are different. N/t unknown sorry.
