Prothan Motor Mounts
hollifm
30
Aug 17, 2004
Columbus, Indiana
Has anyone installed these on a 2g car (Prothan Motor Mounts)? Also what was the vibration difference there site speaks of? I understand the mount is less pliable but can anyone give me an idea of the difference from the stock to the prothan mounts?
Any help would be appreciated.
I've got um, but I also got my balance shafts removed at the same time, so its a little hard to give you an opinion on just the mounts. The only extra vibrations I notices have been at or around idle (bal shft rem). I have noticed that the car doesn't lurch forward and back as much during accel/decel, which if I'm not mistaken is the whole point of the mounts.
Ive got prothane everything + no B-shafts and my car shake,rattles and rolls. so im no good judge either. U will notice more vibration thats for sure.
I still have the balance shafts on my car and the rattle is noticable but, not to bad. You can only notice it at idle so its really a minor inconvience. My biggest complaint is that when my POS windows are all the way down, the rattle like crazy so I always have to keep them semi up. :rolleyes: It was well worth it though, the car feels more solid and wheel hop was reduced.
There WILL be more vibration, but you will quickly get used to it. When you're driving, you won't notice it.
I only put 2 on, the passenger side transmission mount and driver motor mount and it shakes like crazy, if you're a hardcore racer then go ahead but if you use it for daily driving don't do it.....
